4430 lights
Ken HART
12-05-2003 15:51:48
Need help fast. My turn signals stopped working. Lights come on but do not flash. Cannot locate the flasher
WTW
12-05-2003 16:05:56
 Re: 4430 lights in reply to Ken HART, 12-05-2003 15:51:48
Ken, If your 4430 has turn signals the flasher is part of your turn signal switch unit (John Deere calls it a turn signal controller) located at the end of the tun signal lever. DW
Mike
12-05-2003 15:58:06
Flasher should be under the cowl,on left side, somewhere around the breaker panelShould be a square flasher and may be bolted to the dash frame. If you are not going to use a Deere flasher,use a heavy duty 2 prong,standard duty won't last.
