Help With DLTX Carb
Charles
12-05-2003 15:48:01
I just put a new throttle shaft and bushings in my DLTX carb. The throttle shaft seems to be a little tight and I am afraid it will not work properly (It's not the throttle disk). Should I hone down the shaft with very fine sand paper? Or are there any other tricks I should know about?
Thanks Charles
WTW
12-05-2003 16:16:55
 Re: Help With DLTX Carb in reply to Charles, 12-05-2003 15:48:01
Charles, This is very common when replacing bushings. The bushing need to be reamed a little to remove this misfit. If you do not have a straight reamer just use the same size drill bit as throttle shaft on a pair of vice grips and slide it in and out of both bores the same time as it will size the bushings for you. You do not want any binding of shaft as governor will cause the engine to surge. Good Luck, Dave W.
