John Deere B Surprise
Greg
02-21-2002 19:50:36
Could anyone offer some easy way to check my latest problem? I recently purchased a 44B seeming to run like a champ, but when changing oil a piece of metal came out. The metal looks like a shim maybe, half round and 3/32 thick. How can I check this out? Thanks...
Dan
02-22-2002 10:27:07
 Re: John Deere B Surprise in reply to Greg, 02-21-2002 19:50:36
I had a 44A John Deere with a similar piece of metal in the oil. It came from the oil pump drive. There is a sleeve, I have seen them round and square, that connects the oil pump shaft to the governor.
David
02-22-2002 06:00:28
Couldn't it be simply a rod shim that was dropped into the crankcase and simply left there when the bearings were adjusted sometime in the past? I know that when I cleaned out the crankcase of my '38 B I found all sorts of junk at the bottom.
Sam
02-23-2002 05:25:56
 Re: Re: John Deere B Surprise in reply to David, 02-22-2002 06:00:28
Very true about finding junk in crankcases. I would be more surprised if you didn't find some in a tractor that is this old. I once found a complete governor in the pan of a D-14 Allis Chalmers that had been running just fine. When the governor blew up, somebody put a new one in and didn't bother to remove the old parts from the oil pan.
I bet you will find iron or steel particles in the old tractor too. To find out, take the top off and pass a magnet around inside the crankcase. While you have the top off, see if a piece has broken off the back of a cylinder or some other place.
Tide Wilson Martin
01-24-2004 13:03:07
 Re: Re: Re: John Deere B Surprise in reply to Sam, 02-23-2002 05:25:56
Absoshootme u will. Now, get on with it
Deere Puller
02-22-2002 05:31:54
May be a piece of the thrust collar on the LH main bearing - had a '43 "A" with the same affliction once. Although it was supposed to be attached, it did no real harm.
ChuckW
02-21-2002 20:25:55
doesn't sound good. Suppose if it was brass like material with a hole and sort of trapozoid shape it could be a rod shim...other wise sounds like a homemade shim patch job to sell the tractor. Probably wasn't holding oil pressure and this allowed it to run...can take inspection plate off and check for excessive movement. Those old tractor will run with 6-10 thousand clearance however they generally will know and throw a lot more oil than the oil rings can control. Also would have low oil pressure.
mike
02-22-2002 07:07:15
 Re: Re: John Deere B Surprise in reply to ChuckW, 02-21-2002 20:25:55
I found a curved broken cast part in my G when I changed oil about 1 in. wide and about 2 in. long 2 years ago but it runs ok and don't rattle still has good oil preasure so I keep running it.
G-man
02-21-2002 20:38:47
It's steel. The man who sold it was 91, and we started it in below zero weather with no trouble. Everything was full of mud from the mud dobbers and he said it was in the barn for 16+ years. It seems to have good pressure and the plugs haven't fouled yet. I'll check for the excess play, and hope for the best. Thanks for the help.
ChuckW
02-22-2002 03:41:56
 Re: Re: Re: John Deere B Surprise in reply to G-man, 02-21-2002 20:38:47
then you've got me...I don't know any part that would be a piece of steel like that....the rods are babbitted....there are oil lines....there are thrust plates but they are circular type items...maybe some umpteen years ago someone dropped something down in case...a JD mechanic friend of mine said a customer complained about a severe noise in large tractor...finally he tore into in and JD factory had left a large wrench floating around inside...just hadn't been able to totaly do it's thing....your question may be one for the Mr. Thinker.....
