820-830
52 A Boy
02-21-2002 19:10:16
What is the difference between a 820 and a 830 John Deere. Thanks for any info.
G Taylor
02-22-2002 08:03:38
 Re: 820-830 in reply to 52 A Boy, 02-21-2002 19:10:16
Mechanicaly there is more difference between a green dash 820 & a black dash 820 than there is comparing the blackdash 820 to the 830.
Rman
02-21-2002 20:32:37
Injectors, pumps, timing and camshaft. Bout all thats different. Same CID on engine. Different sheet metal, few different options, thats about it.
Robert
02-22-2002 07:16:20
 Re: Re: 820-830 in reply to Rman, 02-21-2002 20:32:37
There are the older large two cylinder and newer small three cylinder utility tractors, and they all go by 820-830. The utilities were made in Germany.
Brandon
02-21-2002 20:07:45
Mechanically, they are the same. The engine may have gotten slightly better injectors, or other details, but basically the same.
The 820 was only avalible with a pony engine start. The 830 could have that, or an optional 24 volt electric start system.
The major difference is a new look. The sheet metal is different. You'd have to find a picture of an 820 and 830 to tell the difference.
Good luck,
Brandon
