JD 507 Gyramor
David
12-05-2003 13:45:05
Hello,
I have an old JD 507 gyramor, seven foot finishing mower. It is the pull type model. It cuts great and I have no complaints. I was wondering if the parts ( gear box, clutch, pullies, ect.) from a three point JD 507 would be interchangeable. I found a broken three point model and thought it might be worth the asking price to have spare parts for my pull behind model.
Any advice would be greatly appreciated.
THANKS,
David
MIKE HANLEY
12-05-2003 17:39:17
 Re: JD 507 Gyramor in reply to David, 12-05-2003 13:45:05
You confuse me. You say gyramor and then say finishing mower. The gyramor was a brush cutter rotory mower. A finishing mower is what the schools use to cut the lawns in front of the school and the village uses to cut the grass in the park. The finishing mower fits on the 3 PT of tractors and has large rollers the full with of the mower ahead of and sometimes behind the cutters to keep the mower from sclaping and giving the lawn the look as if it was cut with a regluar lawn mower. But I'm guessing that you are asking about the brush rotory mower. I would check with the John deere dealer for sure, but what I've seen of the older rotory cutters is that the series has the same gear box no matter what the with of the cut is. The gearboxs are rated for horsepower, and then can be bougth in 5' 6' 7' cuts. Example, we have a 506 that is rated at 60 horse power on the gearbox. All the moving parts are except the blade assembly. The 506 cuts 5 foot wide the 606 cuts 6foot wide and so on. The decks are the same for that cut and what is differant is weather it has a 3PT or has transport wheels. When John Deere first came out with the gyramor there were just two. The reg duty 5 foot 127 and the heavy duty 5 1/2 foot 207 and they stayed in the line a long time. John Deere keeped things pretty simple on rotory cutters through and up to the "X" series rotory cutters. But even the "x" series are rated in the sales lit with the gearbox and the the with of the cut within that series.
MIKE HANLEY
12-05-2003 18:07:08
 Re: Re: JD 507 Gyramor in reply to MIKE HANLEY, 12-05-2003 17:39:17
PS We had a 127 that we got in the late 1960's and really were into some heavy stuff with that one. Then one winter we forgot to loosen the slip cluch. It's covered in the ops manuel for proper storage. Well the cluch set up and rusted tite. Bought a used 506 at a auction cheeper then I could buy cluch parts for the 127. The 506 had the bearings out because the lower seal was shot. Replaced all that stuff and haven't spent a dime on it since. The 506 is sheap pin instead of the slip cluch. We use a grade #8 bolt for the shear pin and only shear the pin when we hit rocks. We use it mosty on a 420 crawler (28 HP) in the woods, but had had it on the 730D (58 HP) in open pastures and have lugged the 730 down in heavy going. What I'm saying is that in over 40 years of heavy use with the two gyramors, the only proplem we have had was the cluch and that was our fault.
David
12-08-2003 09:17:06
 Re: Re: Re: JD 507 Gyramor in reply to MIKE HANLEY, 12-05-2003 18:07:08
Thanks for the info.
Eric D.
04-27-2004 20:07:11
 Re: Re: Re: Re: JD 507 Gyramor in reply to David, 12-08-2003 09:17:06
David:
Recently purchased a 507 Gyramor and need an operators manual. Do you have one and if so would you make a copy? I'll purchase it.
One of the responders said he didn't loosen the slip clutch for over wintering and it was damaged. Could you please tell me what he meant?
Appreciative, Eric D.
david
05-07-2004 13:11:41
 Re: Re: Re: Re: Re: JD 507 Gyramor in reply to Eric D., 04-27-2004 20:07:11
Hi,
I have the original manual that came with the mower, and I also bought a reprint off eBay. I would be glad to help out however I can.
The mower has a slip clutch that if not maintained can become rusted/fused together. If the mower hits a stump (for example) the clutch is designed to "slip" so that the mower and tractor are not damaged. It kind of works like a shear pin.
I hope this helps..... I am not an expert be any means.
