How to get the steering wheel off
John
02-21-2002 13:48:53
How do i get my steering wheel off my early styled B i got the big nut off what next. do i need to use a puller??? thanks for the help
old bones
02-21-2002 20:46:09
 Re: How to get the steering wheel off in reply to John, 02-21-2002 13:48:53
take the nut off, put a 3 jaw puller on the steering wheel hub, tighten the puller as tight as you can get it, smack the bolt on the puller (straight on, like you're trying to drive the bolt into the steering shaft) with a hammer, retighten, smack, repeat, etc.
Larry E
02-21-2002 19:05:21
Turn nut to where it is flush with end of shaft have someone smack it with a hammer ,while you pull on it .
Mark J
02-21-2002 14:09:18
I have chipped the back of the hub of the wheel by striking it with a hammer.
To avoid this, I rig up two steel bars on the back of the wheel spokes and then use a two jaw puller.
Be carefull as when the wheel breaks loose, it flies off with great force and would break a nose or worse.
Good luck
easydoesit
02-21-2002 14:00:11
The following plan works for me.....Lay a large hammer on the steering shaft and tap the back of the steering wheel at the hub all around. You might get your wife to turn the wheel slowly. If you're worried about scratching the shaft lay a cloth on it.
