MT (AFTERMARKET) 3 POINT HITCH
BARRY
12-05-2003 12:50:41
I WANT TO PUT A AFTERMARKET 3 POINT HITCH ON MY MT..DOES ANYBODY KNOW WHO MAKES THE BEST HITCH OR AM I WASTEING MY TIME..THANKS
Bill Thomas
01-01-2004 22:23:56
 Re: MT (AFTERMARKET) 3 POINT HITCH in reply to BARRY, 12-05-2003 12:50:41
My son and I are just about finished with building a 3 point hitch for his John Deere M. It would be the same set up as the MT. We looked at all of the hitches on the market and did not like the fixed width versions that bolt on to the drawbar. Unfortunately the alternative is to loose the drawbar because it is in the way of designing a proper hitch for this tractor. I am an engineer, so I decided to design one from scratch using conventional cat 1 lift arms. We have about 3-4 more hours of work to complete it and then we will test it for proper clearance. If you havent already found the hitch you want let me know if you would like us to build one for you. I can send some pictures of ours as soon as we complete it.
Bus Driver
12-05-2003 16:48:09
Any of the 3 point conversions on the M series tractors results in a system much less versatile than most of the 3 point systems.
andrew
12-05-2003 14:22:48
tony carbaugh in wa or or makes a good one do a search on google for his name. Nice folks to deal with, quality product. Got one for my MT earlier this year. Just make sure your hyd are up to the task. Light lifting only compared to a true 3 point hitch on a later tractor.
jdman(MO)
12-05-2003 16:30:05
 Re: Re: MT (AFTERMARKET) 3 POINT HITCH in reply to andrew, 12-05-2003 14:22:48
Looks o.k. but where is the center link? Should be something that bolts over the Belt pulley hole to use a center link. Russ
