430 oil pressure
Bguy
02-20-2002 19:11:30
I have a 430 that pegs the oil pressure gauge when running. It has a new gauge (all of the gauges are new) and I don't know if it did the same before or not. Can you adjust the pressure like on the B's and etc?
ChuckW
02-21-2002 04:28:52
 Re: 430 oil pressure in reply to Bguy, 02-20-2002 19:11:30
I had a 430 that showed a lower reading. It was electric type. Upon using a regular line guage I found that the tractor had the proper pressure. Unscrewed the sending unit and screwed the new gauge in. If you have the electric I'd check this before I did anything else. Those electric gauges are tricky.
JDM Guy
02-21-2002 02:59:49
Bguy,
That gauge you bought may only go up to say... 10PSI when the tractor's PSI is 15 so the gauge pegs. Yes you can, you have to take the oil pan off and there is a ajustment screw at the front.
