In vs out board planetary drive
Tom Rothermich
02-20-2002 08:51:03
I an evaluating bids for a 15' backhoe. John D says tha inboard planetary drive is a better drive , while others say it is no better & a real pain to work on. Comments please
JD70Jim
02-21-2002 07:19:29
 Re: in vs out board planetary drive in reply to Tom Rothermich, 02-20-2002 08:51:03
Check this out yourself. Look at the rear axles from an AC 180-190xt and then look at a 3020-4020. Which rear axle housing and rear end do YOU think looks stronger?
Ever since those tractors were new, I have had the opinion that AC tractors prior to their 7000 series looked to have weak rear ends. And they have your outboard planetary system. They also have higher clearance under the axle, but it sure LOOKS weaker. Having never operated one of them, I just don't know about how they work in practice. I am also suspicious of the extra oil compartments as well. (K.I.S.S.)
Steven M
02-20-2002 16:44:29
I know the John Deere inboard planetary drive is better then a out board.
The inboard is lubricated with filtered transmission oil.They also use 3 planet pinions.
I had a Massey Ferguson 65 tractor,it had out board planetary drive.The out board,has it's own oil compartment,with oil seals,when the seals leak,that's it,no more oil. Massey Ferguson has only 2 planet pinions.By the way. When the oil leaks to the inside,it gets on the brake. Then you don't have a brake on that side.
