JD VanBrunt grain drill
T.Schmitz
02-18-2002 05:41:50
I have a chance to buy a Model B JD Van Brunt grain drill with grass box on rubber tires. Seems to be in excellent condition does anyone know the value or the history.
Frank
02-18-2002 07:37:06
 Re: JD VanBrunt grain drill in reply to T.Schmitz, 02-18-2002 05:41:50
I have two FB JD VanBrunts. I paid $150 dollars for one field ready, and $50 dollars for one that needed a couple of parts. I needed to replace the springs, three feed tubes, and three feed cups. I bought the cups for a buck a piece at the local salvage yard, So I have about $75 dollars in it, and it works great. The newer of the two has one mechanical lift and the older one has two. I have had some problems with them getting out of sync, but that was all. $500 is a bit much for one. I would like to find some way to hook theme together and use them at the same time. I have seen pictures, but only from the back side. There are pictures of it at the implement photo gallery. Type in John Deere Van Brunt where it says search.
DennisLCook
08-22-2005 19:09:35
 Re: Re: JD VanBrunt grain drill in reply to Frank, 02-18-2002 07:37:06
Please contact me if you know where I could get 7 feed cups for my Van Brunt drill. Thanks alot.
Norman
02-18-2002 05:52:16
T, I bought one about 3 years ago and paid $500.00 for it. I don't know why. Guess cause I thought I wanted it. Later
Norman
