How do I get those bolts loose..??
Clyde Scott
02-17-2002 06:28:04
Restoring a '46 SD model A and want to replace the cork seal in the flywheel assembly and give it a good cleaning while I have it apart but I cannot get those bolts loose on the back side of the wheel. I do not have a flywheel wrench. Any suggestions? I have tried the knuckle joint on my 1/2" drive socket and also tried to use an impact tool. I'm stumped..!! Thanks
Clyde Scott - Moultrie, GA
Shorty Dear
02-17-2002 17:47:52
 Re: How do I get those bolts loose..?? in reply to Clyde Scott, 02-17-2002 06:28:04
Clyde,
Original flywheel wrenches aren't cheap, but they are the only tool that will tighten and loosen the flywheel bolts effectively. I have them for sale if you would like one?
Mike Aylward
02-17-2002 17:36:37
Clyde, the "regulation" wrench for these flywheel bolts is the best thing to use, but if you don't have one of these (like I don't) you can possibly do what I did. I heated a 3/4" drive socket extension and bent it in a modified "S" shape with about 3"-4" of offset. You can use your regular 3/4" sockets with this setup. Go to a hardward store and buy a cheap one that you can heat and bend and you will be fixed right up. Not a pretty fix, but effective. Mike
Paul from MI
02-17-2002 17:25:49
Clyde,
I read some of the responses, but don't think much of heating the flywheel bolts to loosen them. They are probably one of the most critical pieces on a John Deere tractor. Besides, I presume you will put the flywheel back on later and you'll need a good way to tighten the same bolts. I made a wrench that sort of simulates the old original ones but uses 3/4 drive sockets. I've used it on my A,B,&D, and I loaned it to our local dealer who used it on a G. If you want I can e-mail a sketch. You may be able to borrow an original wrench or even find one if you advertise. I would consider new bolts a real good investment when you put it back together. Lots of luck, Paul
Tractorboy
02-17-2002 09:48:06
Clyde just heat them up staying away from the mains with the torch as they will come loose
Lonnie
02-17-2002 16:16:31
 Re: Re: How do I get those bolts loose..?? in reply to Tractorboy, 02-17-2002 09:48:06
The best way to get them off w/out heat (which may hurt babbitt bearings) I to get 2 sockets & a piece of 1half inch thick x 1.5" wide x 3" long bar stock or whatever size you can find that is close & weld the sockets to the bar stock in such a way to give an offset effect when putting the soket on the nut & the half inch drive extension on the other socket. I had one made & it works nicely & it gives me more leverage when tightening the nuts. You sure don't want a loose flywheel.
S.A. Beatty
02-17-2002 07:07:04
I took a small torch and heated the nuts. They turned right off.
