3020 synchronizers
stuart
12-05-2003 06:21:22
i have split the tractor removed the rockshaft housing and in the process of removing the transmission shaft. How does the pump on the end of the shaft come all the way off. I have removed the pcs that have the tubes going down into the rear housing but have not figured out how to remove the pump all the way off. I assume i need to remove theis to get to the shaft that the shifters slide on so i can get the out of the way to remove the top shaft. any suggestions?
WTW
12-05-2003 07:08:04
 Re: 3020 synchronizers in reply to stuart, 12-05-2003 06:21:22
Once you have removed the pump suction and discharge pipes and manifolds, there is two more 5/16" bolts to remove on the left side of pump. Once these bolts are out then pump will slide to the rear and off the end of the top shaft. To remove the top shaft the bearing cup/race (under pump) has to be bumped back before shaft can be lifted out. To do this raise front of shaft and with a brass drift drive shaft to the rear moving rear race to the back. Race may not come clear out but will move back far enough to remove top shaft by lifting the front out first. Good Luck Dave W.
Bob
12-05-2003 06:51:59
Rotate the differential assembly until one of the flat areas is next to the pump. Pull the pump backwards off the shaft, and upwards off the oil tubes.
STUART
12-05-2003 06:59:11
 Re: Re: 3020 synchronizers in reply to Bob, 12-05-2003 06:51:59
THANKS, i HAVE ALREADY REMOVED THE TWO PCS AND THE PIPES JUST WANTED TO MAKE SURE THAT THE PUMP JUST SLID OFF THE BACK
