 Scott: You don't want to use too much of the high-build primer, because it tends to shrink a little. If it were me, I would apply an epoxy primer to seal everything and prevent re-rusting, the use a light application of a good quality of filler, let it cure well, then work in down with a stiff block. This should bring the bondo down to the existing surface (Try no to cut through the epoxy primer...if you do, spot prime those areas and the areas where the bondo is exposed). Then apply a quality high-build primer. I use a product made by Transtar, but there are certainly others. When it has cured well, block it down, maybe use a guide coat if you think there are any hi/low spots that you didn't see and correct the first time around. When you can block the whole surface with 220 dry and it is defect free, you can apply JD Green or an acrylic finish over it. Here's a picture of a recently completed hood that was pitted VERY badly. Sorry, it isn't green, but you get the drift. The next picture is of the dash panel. The metal was a bit heavier, but the pitting was worse as well. Primed, filled, high-build, paint, color sand, clearcoat. Frank
