JD 4520. hyd. power steering, lift, kaput, after l
Alvin n Ms.
10-16-2003 07:58:43
Had been setting up under a shed for about 3 months.Was started up and hyds. won't work. We have changed the two filters on the left side of the transmission. Pump still begs for oil,but not vigorously. help will be greatly appreciated.I started taking the oil supply suction hose off at the pump with the engine running,and after loosen the screw a little the pressure tried to blow the hose off. I didn't expect any pressure.
twopop
10-16-2003 14:02:33
 Re: JD 4520. hyd. power steering, lift, kaput, aft in reply to Alvin n Ms., 10-16-2003 07:58:43
there is a trans.pump in your 4520 that supplies oil to the main pump,so if the line you took off has pressure then i doubt the screen is your problem,nor the trans pump.I see you changed both filters ,so i gather your 4520 is a powershift.is the destroke lever on the left side of the dash,pushed forward?someone may have pulled it to the rear.if it doesnt have the lever then possibly the destroke valve is stuck in the pump,or it has been set on destroke.
Alvin n Ms.
10-16-2003 17:03:55
 Re: Re: JD 4520. hyd. power steering, lift, kaput, in reply to twopop, 10-16-2003 14:02:33
Twopop,I want to Thank you for the good information. I beleive it will solve the problem.
Best of luck and have a great day.
