Blowing Fuses
mike
02-14-2002 14:48:43
I have a John Deere 1010 that recently has started blowing fuses. I got away once with replacing fuse with #9 wire to start tractor. I don't want to do that and that trick doesn't work any longer and the wire gets very hot I recently removed a mouse nest from under the dash board. Would a shorted or grounded wire cause the blown fuses, or do I have a more complicated problem with which to deal?
Thanks in advance.
Mike
Gpower
02-14-2002 15:22:22
 Re: Blowing Fuses in reply to mike, 02-14-2002 14:48:43
SOunds like you have a wire that is either grounding out, or a short circuit. If the fuse looks black in the bulb, then its a shorted cicuit, melted with no black you have over current. Most likely the rat has been chewing on wires and two are now touching...dont use the wire in place of a fuse unless you want a burned up tractor..seen it a lot. Good luck
Gpower
JD JACK
02-14-2002 15:37:01
 Re: Re: Blowing Fuses in reply to Gpower, 02-14-2002 15:22:22
DIDN'T KNOW THAT YOU COULD LOOK AT A FUSE AND TELL IF IT HAS A SHORTED CIRCUIT OF OVER CURRENT?
ANY SHORT TO GROUND FROM A WIRE THAT IS B+ WILL CAUSE FUSE TO BLOW. ANY SHORT TO GROUND IS A "OVER CURRENT".
WHAT SIZE FUSE IS BLOWING? I LIKE TO USE A BULB AND CIRCUIT BREAKER TO MAKE A TESTER. HOOKED IN SERIES CURRENT WILL PASS THROUGH CIRCUIT BREAKER.
NEED IT OPENS, THE LIGHT WILL LIGHT AND YOU STILL HAVE A SHORT. VERY GOOD TOOL. USE IT EVERYDAY WORKING ON CARS AT AUTO DEALERSHIP.
HPOE THIS HELPS.
mike
02-14-2002 21:56:59
 Re: Re: Re: Blowing Fuses in reply to JD JACK, 02-14-2002 15:37:01
Thanks for the tip. I will try your tester and see whathappens.
