Loder for a John Deere 720 STD
John D
02-12-2002 09:10:23
Hi Can I put a Loder on a 720 Disel STD Thanks John D
Larry
02-13-2002 08:48:14
 Re: Loder for a John Deere 720 STD in reply to John D, 02-12-2002 09:10:23
John, If some of the guys think you can put a 48 loader on your standard, I've got one with the two-cylinder hook ups in the classifieds. It is on a 630 now and has some adjustment in the brackets. The good thing is it mounts to side frame as well as going back to the rear axles. They work great and are a heavy nice loader.
Aaron
02-12-2002 17:50:29
Heres a picture of a Dual on a 730 standard. copy and paste the adress.
Aaron
http://www.burrells.net/antiquetractors.htm
old bones
02-12-2002 14:49:16
came back inside to correct myself, but see it's already been done for me. my eyes skipped right over the standard designation and my brain was thinkin row crop. i honestly don't know on a standard. sorry i didn't get back inside sooner to correct myself. these other gentlemen have more experience w/standards. in my area (nw iowa) i've only seen 1 working standard 30 series, as the row crops were most popular.
John D
02-12-2002 15:17:58
 Re: Re: Loder for a John Deere 720 STD in reply to old bones, 02-12-2002 14:49:16
Thanks any ways What do you think that the tractor is worth in good cond 720 Diesel STD runs tip top Thanks guys.John D
Brokenwrench
02-12-2002 14:13:23
You may have a problem finding one to fit a standard. The mounts on the row crop tractors bolt to the frame and the rear axle. You might possibly have some luck with a JD 48 loader if you can find the 2 cyl. mounts. Even these will require some adapting where they mount to the axle housings as they are different from the row crops. I would not advise using a loader that mounts just to the front frame, theres a good chance that this will snap the frame under heavy use.
John
02-12-2002 14:26:58
 Re: Re: Loder for a John Deere 720 STD in reply to Brokenwrench, 02-12-2002 14:13:23
Some years ago, the local JD dealer mounted some kind of a Westendorf loader on a 70 Standard---and broke the tractor in half---he was dumb enough or stubborn enough that he did it twice!! Don't even think about putting a loader on your tractor unless you have some way to tie it to the rear axle housing. You can't use a No. 45W JD loader, because the threaded holes for the mounting brackets are not drilled in the rear axle housing on a Standard, and you'd have to take the fenders off, anyway, even if the holes were there.
BUDD
02-12-2002 14:05:01
I am not saying you can't put a loader on a 720 standard, but I have not seen a standard with one.
old bones
02-12-2002 11:24:14
absolutely! there are lots of loaders out there to choose from. just be sure you get the right mounts. hand clutchers aren't the handiest to use with a loader, but you can get by fine after you get used to it. i've had one on an A, and a 720 will be better- live power, power steering.
john D
02-12-2002 12:17:20
 Re: Re: Loder for a John Deere 720 STD in reply to old bones, 02-12-2002 11:24:14
Thanks do Know what model loder is best for That tractor and how much they cost Thanks . John D
G Taylor
02-12-2002 11:49:28
A wide front tractor will require the Deere 45W loader. A rowcrop would be better with the beefier model 50. For similar US$ and more satisfaction just come up to Canada & with the exchange you can take home a 20 through 40 series tractor with a loader, high pressure/volume hydraulics, power brakes,power steering, shuttle shift. A hydraulic bucket is required or you will curse the trip setup & yourself for buying it.
