JD MT Belly Mount Sickle Mower ??
Mark Hendershot
02-11-2002 17:40:02
I have figured out my JD Mod# 20 Sickle Bar Mower is the Belly Mount type for the JD MT Tractor. It is hung off the engine area with a Clamp and several brackets. The Mower is ran by a drive shaft drivin by a Pulley & Belt off the PTO Shaft. The Pulley is about 10 inches in dia. and has a spline with a bolt to make it tight. This Mower seems to weight around 400-500 lbs. Dose anyone have a picture of one assembled or know the Number for the Manual. I have it all together except the brackets to hang it with. There are a lot of pulleys for a cable set up which I think it is for raising and lowering it with the lift bars. Any help would be great! Mark H.
Tugboat
02-12-2002 14:04:05
 Re: JD MT Belly Mount Sickle Mower ?? in reply to Mark Hendershot, 02-11-2002 17:40:02
Mark; I have a picture of a center mount sickle bar mower on a JD 330 if that would help. I could e-mail this to you.
Tugboat
Stan - Florida
02-11-2002 18:31:52
Mark,
The Operator's Manual is OMH31954 and the Parts Catalog is PC153(01MAY53). As before, call 1 800 522-7448 and have credit card handy.
Stan
Mark Hendershot
02-11-2002 19:36:00
 Re: Re: JD MT Belly Mount Sickle Mower ?? in reply to Stan - Florida, 02-11-2002 18:31:52
Thanks Stan; I have been tring to put all this together for some time and miss some posts or forget. I will write it down. This is the Manual for the Mower? Right? Mark H.
Mark Hendershot
02-11-2002 19:33:37
Thanks Stan; I have been tring to put all this together for some time and miss some posts or forget. I will write it down. Mark H.
