Degreasers
John w.
02-11-2002 13:09:42
Hi, What type of cleaner should I use to clean grease off my tractor,so it can be painted. Thanks for any advice!
ff316
02-12-2002 18:59:48
 Re: degreasers in reply to John w., 02-11-2002 13:09:42
Check with your local industrial cleaning supply dealer like Thomson's Janitorial Supplies or the like. They probably have something that will remove ANY grease, paint, or other gunk off your tractor. When I used to work at a summer camp my boss accidentally got some super strength green degreaser. We thought we could mop with it if we used just a little. We used 2 or 3 oz in a 4 gallon mop bucket and it ate the wax off the floor. It was green, looked about like antifreeze only thicker if that makes sense. Use safety precautions!! Fireman
Frank
02-11-2002 18:46:08
John:
I've tried many different methods of cleaning, and I can't say that any one is the best.
It really depends if you need to clean and leave the old finish behind unblemished. If that's the case, you'll be limited to light alkali cleaners, like the purple stuff. or simple green. For that, I spary it down a couple times with diesel fuel which will help loosen and dissolve the grease and oils. The alkali soap will remove the oil film and dirt. Using a scrub brush will help alot. Follow each application with ALOT of hot water pressure washer time. Get yourself a poncho, and you'll get very wet. Remember, the majority of the filth is on the underside of everything. so I spend wuite a bit of time on my knees and even laying down under it.
It's not a pretty sight.
Finish up with some dish soap to give a real bath, and pressure wash it thoroughly.
If you want to remove the old finish, or at least the flakey paint, along with the grease, the oven cleaner mentioned does work very well. I didn't like the fact that it was so expensive, so I make my own paint removing slurry out of lye, corn starch and water. Mix about a cup of lye in a couple or three cups of water, and add corn starch slowly until it's thick enough to apply with a brush and stay put. I sometimes use an undercoating gun to slop it on. If you let if sit for overnight, it works very well. Take a garden sprayer filled with some more lye water spray it down now and again, so that it doesn't dry out. Once it's been working, stir it around with a stiff parts cleaning brush, and it will do a fine job. when you're ready to hose it off, just use a low pressure so you don't spray it into your eyes. After it's thinned out, turn to your pressure washer, and take the paint off with the dirt. It may take several applications, but the ability for it to remove the old paint is pretty amazing.
Give it a try. it's fairly cheap and it works.
Frank
RLA
02-11-2002 14:57:55
One idea, see if there is anyone in your area who sells Korkay products. They have a biodegradable engine cleaner we use here at work. This product mixed with hot water is totally SUPER. Evan on old, old dryed on Grease. RLA
rco
02-11-2002 13:54:00
high pressure washer with hot waterheater on the washer works very well. my guess is that it works the best
Roy
02-11-2002 14:16:19
 Re: Re: degreasers in reply to rco, 02-11-2002 13:54:00
Use oven cleaner and high pressure washer, works really great
