JD 420W will not charge
Andy
02-11-2002 10:22:57
I have a 1956 420W with the original 6 volt positive ground system. My ammeter shows a discharge when the tractor is running and goes way down when I turn on the lights. I have installed a new generator and get the same results. How can I find out what is wrong with my charging system? Is the voltage regulator bad? Or maybe is my ammeter hooked up wrong? Please help!!
Clooney
02-11-2002 15:59:05
 Re: JD 420W will not charge in reply to Andy, 02-11-2002 10:22:57
Andy, did you polarize the generator after installation? If it wasn't done that could be your problem. Just momentarily jump a wire from the big battery post on the starter to the (A) post on the generator (the biggest of the two) & if you see a spark you are done, if no spark use a jumper wire & ground the (F) post on the generator & jump the (A) post to the starter post again. CAUTION: do not EVER touch a hot wire to the (F) post on the generator. ~If that doesn't start the charging cycle make sure your regulator has a good ground (important, it won't charge without a GOOD regulator ground), if that is ok run the tractor at fast idle & ground the (F) post on the generator, does it charge now? if so you either have a bad regulator or the field wire between the generator & regulator is open. If it doesn't, leave the ground wire on & use a jumper wire & hook the (BAT) terminal on the regulator to the (GEN) terminal on the regulator, does it charge now? If so you have a bad regulator, if it doesn't the wire between the (A) post on the generator & (GEN) terminal on the regulator is open or the generator is bad. If still no charge make sure you have battery voltage at the (BAT) terminal on the regulator.
