JD 70 Crankshaft Material
Eric Horne
02-11-2002 08:38:10
I was told that a crankshaft out of a 70 LP was made from stronger material than an 70 Gas crankshaft. Fact or Fiction??
I see they have different part numbers. I want to have my facts straight before I unload them. Thanks.
Mike Aylward
02-11-2002 09:35:27
 Re: JD 70 Crankshaft Material in reply to Eric Horne, 02-11-2002 08:38:10
Eric, you heard right. The LP cranks were made out of an alloy steel to help withstand the higher compression ratios of the LP tractors. If you look in a parts book you will likely notice that the LP crank is the factory substitute for the regular gas crank. Hope this helps. Mike
