I have a horse drawn sod plow could it be a John Deere?
R Wyler
02-10-2002 16:46:06
I have my great great grandfathers hosre drawn sod plow the was used after the Cherokee strip land run of 1893 in north central Oklahoma. It is problably around 105 years old or older. It is made of steel execept for wooden handles and the front of the beam has a two peice cast iron bracket bolted to it with several holes in it. I can tell by looking that it is a factory built plow the share is made of steel and is flat and sharp. behind the share are some round rails to slide the sod off to the right hand side. There are some numbers stamped on one of the brackets attaching the handles to the plow. And on the front cast iron clevis toung there are some slight spots of green paint. I do not see the famous John Deere fancy D stamped in it or any name of any kind. Could someone help me identify the manufacturer of my sod plow? Thanks.
