JD400 94 series backhoe
RHB
02-10-2002 15:02:52
1972 JD400 needs bleeding?
When I start her up, the hoe mostly but also the bucket are all but dead. Fluid is full. The more I work her the better she gets but still seems weak. Is there a specific procedure for bleeding the hydrolics ? I'm guessing I have an air problem?
cannonball6
02-11-2002 05:41:35
 Re: JD400 94 series backhoe in reply to RHB, 02-10-2002 15:02:52
have you cleaned your screen on trans pump ? sounds like as it gets warmer the fluid gets thinner and flows better ..you cannot work much with trans pump starving....have nice day
