520 manifold
alcgar
02-10-2002 10:40:40
Can I remove and replace the manifold and gaskets on my 520 without removing the powersteering pump shaft and the upper water tube? Thanks in advance, Al
Dan
02-10-2002 18:15:57
 Re: 520 manifold in reply to alcgar, 02-10-2002 10:40:40
yes you can,I like to spray the studs with pb blaster for at least a week or so before I attempt to breakem free.I think I have saved myself a lot of agravation by being patient and doing this.By the way I just did a 520 and had no problems,put a little antiseize on the new studs you never know when they might have to be removed again. hope this helps
alcgar
02-10-2002 16:40:15
Thanks for the info. Al
BJ
02-10-2002 12:10:46
Yes you can but the bigger problem arises if you have any studs twist off then the fun starts I done one a month ago and 3 studs broke off wound up taking the head off to get them removed but no big deal
Steven M
02-10-2002 11:46:45
On a 520 you can remove the manifold without removing the fan shaft or upper water tube,because they use cap screws to hold the manifold,so you can slide the manifold out.
On tractors like the A or B they use studs with a nut on top to hold the manifold,so you can't slide the manifold out.
