4400 A\C
John
02-07-2002 16:23:02
Since the summers seem to be getting hotter anymore i though it would be a good project to fix the ac on it. It has a Delco compressor on it. How could i get this thing to work again? Within reasonable price range though.
Carl R
02-08-2002 21:13:37
 Re: 4400 A\C in reply to John, 02-07-2002 16:23:02
Any A/C system can be fixed--it just depends on how much money you are willing to spend. If the system has been empty for a long time, the cost goes WAY up due to the labor required to flush the contaminants out. Moisture in air reacts with R-12 and one of the byproducts of this reaction is hydrochloric acid. This acid will destroy aluminum, and there is a lot of aluminum in an A/C sytem.
Going back to R-12 would be expensive just for the cost of the refrigerant alone (4 lbs @ $50/lb). R-134a is a lot cheaper ($6/lb) but runs a lot more pressue and is not as efficient. If your compressor is shot, get a Delco 134a compressor from your JD dealer as is already has the right synthetic oil preinstalled. The seals and other internal components are designed for higher pressures as well. The receiver/dryer MUST be changed and the entire A/C system should be flushed. The expansion valve should be changed and the hoses should be closely examined, expecially the hose that runs from the compressor to the condensor. This hose handles all the heat and pulsations from the compressor and will usually be the first one to go. If you can turn the rubber part of the hose while the metal stem stays still--that is a leak--replace the hose.
Another good way to find leaks is to charge the A/C system with dry nitrogen (200-250 psi) then go over every inch of the system with a spray bottle of kids bubble mix. You see a bubble, there is a leak. Wear eye protection and be careful. I would make this the first step so you could see how many things need replaced before you get started. $1000+ would buy a lot of ice and cool beverages!
