420 12v conversion
TIM
02-07-2002 11:35:40
How do you change a 420 from 6v to 12V?.
John T
02-07-2002 17:44:59
 Re: 420 12v conversion in reply to TIM, 02-07-2002 11:35:40
Tim, change the battery, change any lights to 12 volts, add a ballast resistor in series with the high side of coil (where it gets power from switch) to reduce its voltage to 6 volts, and you can either use an alternator (but that requires change over to negative ground for most) or change the Voltage Regulator to a 12 volt unit, Ol John T Nordhoff in Indiana. Post back if you need info on an alternator or conversion to neg ground, myslef or Clooney and others have posted those directions numerous times below.
Steamer
02-07-2002 12:43:18
Change battery. Change generator to all-in-one alternator. You'll have to fabricate a bracket. Remove regulator (unnecessary with alternator). Put ballast resistor in power lead to coil (so as not to fry it). Change lights. Starter will work, just don't grind on it long as the heat buildup will be greater than it was with 6v.
I'd not bother to do this, though, preferring to maintain the original 6v system. That said, I do have one tractor in my collection, a 430w, that was converted when I got it. I haven't started a restoration on that one yet, so I haven't returned it back to original.
440Sam
02-08-2002 19:44:51
 Re: Re: 420 12v conversion in reply to Steamer, 02-07-2002 12:43:18
Tim:
Why convert to 12v - We have a 430S that was purchased several years ago that had a cobbled 12v conversion. We purchased a new wiring harness from JD, had the starter and generator checked at a local auto electrical shop installed a new voltage regulator and it starts better than most 12v conversations I have seen. We even get about 5 years out of a 6v JD battery. The only reason I would consider converting to 12v is if the tractor is equipted with a front mounted hydraulic pump.
Sam
