John Deere Model 50 tractor
Roger Greuel
02-07-2002 11:17:45
Does anyone know the dimensions of a 1955 John Deere Model 50 Tractor. Need length,width and approximate weight. Am thinking about ordering a new gooseneck trailer and will have this tractor in future. Cannot find a web site that gives dimensions or specs on old tractors.
phil
02-08-2002 10:17:46
 Re: John Deere Model 50 tractor in reply to Roger Greuel, 02-07-2002 11:17:45
Roger, I use a 7000 pound Car Trailer for my late model B. Tractor weighs about 4400 pounds. I set the tractor wheels about 4" from the end of the axles - that gives me about 3 inches of clearance between the trailer fender & the tractor tire. Have hauled cross country, pulls & trails well. Phil in Arizona
Michael
02-07-2002 23:38:53
front width-86.62 inches
height to radiator-59.87 inches
Stan - Florida
02-07-2002 16:23:15
Roger,
Here are the specs from a July 1954 sales brochure:
Overall width 86-5/8"
Overall length 132-3/4"
Overall height 82-3/16"
Height to radiator cap 59-7/8"
Shipping weight 4435 lbs.
The rear wheel tread is adjustable from 56" to 88", which means that you could put the rear wheels in far enough to clear the fenders on a standard version modern day tandem axle trailer.
Stan
Kerry Miller
02-07-2002 19:35:18
 Re: Re: John Deere Model 50 tractor in reply to Stan - Florida, 02-07-2002 16:23:15
I hauled my 1955 JD 50 LP on a standard tandem axle trailer, but it was so close that it pushed the side rails out on both sides at the same time! I got the back wheels in as far as they'd go after much heating, beating (and my friend's swearing...)
Be careful loading those tricycle tractors!
Kerry
Don
02-07-2002 14:51:17
I have the specifications on a late styled B which should be fairly close to a model 50. The over-all height is 79 7/8". Over-all length is 132 1/4". Width over axles is 86 11/16". Wheel base is 90". Shipping weight (dry) is 4070 Lbs. HTH. Don
