Is my H overheating
william
02-06-2002 20:18:28
got the old girl out of the barn after sitting for 2 years got the mag rebuilt cause it was no good now starts and runs great and seems to be that it heated up i took a stone boat we drag with our horses and thats loaded about 800lbs of rock just to exercize her and within 5 min was up to about 230 f the bottom pipe was cold and you could not touch the top pipe
Jerry S
02-07-2002 06:52:44
 Re: is my H overheating in reply to william, 02-06-2002 20:18:28
If you left the drain plug out of the head, that is a perfect size for a mouse to get into and make a nest. That is a common problem.
dan_41jdh
02-07-2002 05:04:54
William, John T is probably correct in the diagnosis of no circulation. You mentioned antifreeze in your response to his post. It makes one wonder if you properly premixed the replacement antifreeze solution. If one simply pours in unmixed antifreeze and water, the antifreeze, being heavier, will stay at the bottom and will effectively block any thermo-syphon action of coolant circulation. The result is a quick heat-up.
Stan - Florida
02-07-2002 06:51:38
 Re: Re: is my H overheating in reply to dan_41jdh, 02-07-2002 05:04:54
Had a similar problem with my '41 B - added some Bars Leaks without having the cooling system warmed up. Had to drain it and start all over.
(I hope this isn't a double post)
Stan
ET
02-07-2002 04:39:41
Look for a mouse nest in the top tank.
John T
02-06-2002 21:04:23
William, it sounds like you may have a coolant circulation problem and I have also seen the blocks water passages so clogged up they cant circulate and cool. I wouild start with a real good total flush and see if it helps, but I have seen the heads/blocks so full of crud a flush wont clear them out. Ol John T Nordhoff
william
02-07-2002 03:48:34
 Re: Re: is my H overheating in reply to John T, 02-06-2002 21:04:23
this machine was totally rebult 5 years ago and only run for about 10hrs then the mag let loose and was parked all the gas and antifreeze was drained then so i think i am all ready past that point i was wondering about the rad. cap i was thimking maybe someting was wrong with it
Larry W.
02-07-2002 05:55:33
 Re: Re: Re: is my H overheating in reply to william, 02-07-2002 03:48:34
It shouldn't have anything to do with the radiator cap. The other guys are right. I am sure it is one of the things mentioned. Also, if your temp gauge says 230, there is something wrong with it. The old bugger can't get that hot without some boiling going on which would naturally cool it down. Unless you have the wrong radiator (pressurized) which was used a short while during the war years.
