JD60 cylinder block removal
Leon R
02-06-2002 13:11:40
I need some suggestion/ideas on how to break the gasket seal to remove the cylinder block from the crankcase. I am afraid if I beat on too hard I may break it!!! Thanks
RLArmstrong
02-06-2002 16:59:20
 Re: JD60 cylinder block removal in reply to Leon R, 02-06-2002 13:11:40
Leon, Just a note, make sure that you have removed the two bolts that come up through the frt frame into the bottom of the block. But like you I would beat too hard. RLA
Frank
02-07-2002 09:38:01
 Re: Re: JD60 cylinder block removal in reply to RLArmstrong, 02-06-2002 16:59:20
When I took the block out of my 70D, I found a bolt threaded into the side of the frame (I guess it's a remnant of an implement mount), and it interfered with the block removal until I screwed it out a bit.
On those blocks, I found that if you can't shake them loose by grabbing by the head studs and rocking the block, you probably still have a fastener or two in place. And like was stated, those two big through bolts on the bottom tend to be overlooked.
This is why I really like a parts book. It helps me as much on disassembly as it does on re-assembly.
Of course, you could be the victim or 30 year old Permatex !
Good Luck !
Frank
