Clooney, John T. Anyone.. Generator Ques.?
Wayne in Tn.
12-04-2003 10:34:43
I am getting ready to completely re-wire a 40. At the present it has no wiring at all. I wanted to make sure the generator is ok first. Took it apart, and re-soldered a loose wire at the F post, new brushes and a clean up. Now the question....The generator will (motor) by hooking it to a battery charger on the bench. Now I have it mounted on the tractor,(still no wiring) I start the tractor with a jumper wire to the coil, BUT with a test light on the (F) or (A) post on the generator, it will not burn the test light. Is it supposed to, at wide open throttle???
John T
12-04-2003 13:45:53
 Re: Clooney, John T. Anyone.. Generator Ques.? in reply to Wayne in Tn., 12-04-2003 10:34:43
Sorry Im late getting here Wayne, I been at Henrys helping work on a darn 420. Anyway, if she motors with power applied to the ARM post and frame, that tells you the armature and brushes are probably okay and if when motoring if you dead grounded the field post she slowed down a bit, the Field windings are probably okay. On testing at the Field and ARM posts, its the Armature where power comes out and unregulated and unloaded it may be anywhere even high as 20 volts depending on RPM, so be careful what you attach there. To charge at anywhere near max rate, however, the Field post needs a ground, which is what the Volatge Regulator or light switch field control regulators provide. Current from the ARM post, to and through the Field windings, then to ground is how the field draws current and creates the magnetic field in which the armature rotates producing energy and the more current the greater the magnetic field strength and more energy she puts out.
So try groundign the field when motoroing and see if it slows down and then when you check for voltage at the ARM post have the field grounded.
Let us know and e mail [email protected] or post back any questions.
Good luck n God Bless ya there Wayne
John T
Wayne in Tn.
12-04-2003 15:41:32
 Re: Re: Clooney, John T. Anyone.. Generator Ques.? in reply to John T, 12-04-2003 13:45:53
John T. and All, thanks for the generator lesson. Mine checked out fine after doing all the tests, now just a matter of re-wiring and hope the regulator works. That is something I had never thought about,,, the fact that grounding the field is how it works, simple but amazing. Thanks again. Hey! I bet its COLD over at Henrys, come on down to Tennessee, and work on a 420, its warmer here, but wet today...he..he..
John T
12-04-2003 16:19:31
 Re: Re: Re: Clooney, John T. Anyone.. Generator Qu in reply to Wayne in Tn., 12-04-2003 15:41:32
Henry has a nice warm shop with heat and powered chain hoists and a lift so its fun there lol. He used to run a brake and alignment shop which his son Ben now runs so they have all sorts of tools and equipment plus he has a paint booth in another end so Im in hog heaven there. You going to GOG next March ??? John T
Wayne in Tn.
12-04-2003 17:48:24
 Re: Re: Re: Re: Clooney, John T. Anyone.. Generato in reply to John T, 12-04-2003 16:19:31
John T. I would like to go to the GOG, if health permits. I have never been. Thanks much for the advice, got the wiring done tonight, and she works great. The amp needle stays on the (plus) side, but does a lot of wiggling back and forth, never to the (minus) side tho. Is this normal, not to hold the needle steady?
John T
12-04-2003 22:19:41
 Re: Re: Re: Re: Re: Clooney, John T. Anyone.. Gene in reply to Wayne in Tn., 12-04-2003 17:48:24
Wayne, some things that I can think of that might cause a jumpy ammeter needle are an uneven rough commutator or rough brushes, the mica insulators between the commutator segments not undercut sufficiently, the brushes are worn or are not held down tightly or even in their holders, (things that prevent good smooth even brush to commutator contact) or maybe the contact points in a voltage regulator burned some if it has a regulator. Also, maybe a loose ground connection to the generator or regulator or even a loose connection which vibration is affecting??? Did you have the armature out and smooth the commutator or mess with the brushes?? Run her some and see if she smooths out maybe and check the grounds and connection??? If this dont fix it, take 2 aspirins and call me at the office lol. John T
Clooney(generator test)
12-04-2003 11:54:15
Wayne, now that the generator is mounted on the tractor, the first thing you need to do is test it again, but this time also test the field.... To do that, remove the belt, then run a jumper wire from the starter's battery cable post to the generator's [A] post {larger of the two} ,, the generator should start to motor [just like on the bench],, then ground the generator's [F] post {smaller of the two} to the generator's case,, the generator should slow down,, if it does, it is probably working correctly.. If the generator doesn't slow down when the [F] post is grounded your field is still not working correctly..
~If the generator works correctly per the above test,, then start the tractor & run it at fast idle, then ground the generator's [F] post,, it should then start charging & produce power on the [A] post...Be careful using a test light as that generator can produce over 18 volts [open circuit] & could even blow out a 12 volt test light.. Maybe run it at about 1/2 throttle for a voltage test on the [A] post with a 12 volt test light..
~If your generator motors & slows down but still doesn't light a test light on the [A] post you might have a brush that isn't making contact with the generator spinning with a belt load on it...
~Those Delco generator's operate by grounding the field [F] post & that in turn produces magnetism in the field coils.. That magnetism induces a current flow in the rotating armature & then out through the insulated brush to the [A] post. The [A] post is where the actual charging power comes form.. All the [F] post does is control the amount of magnetism in the generator's field coils by the how much resistance it has to ground ... The less resistance between the [F] post & the case the more current the generator produces.. Simple System isn't it??
~This is a fairly simple explanation of how your system operates, there is more to it but there is no need to make this more complex than it needs to be or it becomes more confusing than helpful....
~Any questions on the above just post back or E-Mail & we'll go into more depth on the areas you need information on..
[email protected]
Bob M
12-04-2003 11:41:55
Wayne - The generator F terminal must be grounded in order for the generator to build up voltage. If the generator is good you'll then see an output at the A terminal. However be aware that without a battery connected to act as a ballast a 6 volt generator can create 15 - 18 volts at full speed and open circuit. And 12 volt generator can show 30 volts or more. Best to test the output with a voltmeter - a 6 or 12 volt test light will go off like a flash bulb on 30 volts!
Wayne in Tn.
12-04-2003 13:19:37
 Re: Re: Clooney, John T. Anyone.. Generator Ques.? in reply to Bob M, 12-04-2003 11:41:55
Thanks guys, I will print out your answers and head back to the shop.
