Correct sized plow for JD 40s
kirk
02-06-2002 09:04:15
I am looking to buy a plow for my JD 40s but am not sure what size plow the tractor can
handle. The JD manual says a 2 bottom plow but doesn�t tell whether a 12inch, 14inch or
16 inch plow. Anyone with info please let me know. Thank you.
kirk
Richard
02-06-2002 15:31:10
 Re: Correct sized plow for JD 40s in reply to kirk, 02-06-2002 09:04:15
The model 412 a 2X14 plow was sold mostly for the model 40 tractor. I see them for sale quite often 200-300 dollars.
DaveH
02-06-2002 14:50:20
I pull an old model 5B 2-12" with my 40U. Around here we have some pretty heavy soil and I think it would load my tractor too much to pull anything larger. Good luck finding yourself a plow.
lc
02-06-2002 13:33:49
I have the original disc breakers that came with mine. I think they cut about 10-12 inches. I believe the 40 would be happier with 12 inch plows in most soils, but with weight in the tires could handle more.
JR Ohio
02-06-2002 12:57:32
My 40T handles two 14" very good.
Stan - Florida
02-06-2002 09:44:27
It depends on the soil type if you're going to use it to plow with, but here are the options given in a sales brochure from July 1954:
No. 411 One-Bottom Plow is available with 14- or 16-inch bottom for "40" Standard Tractor and with 14-, 16-, or 18-inch bottom for the "40" Tricycle tractor.
No. 412 Two-Bottom Plow is available with 10-, 12, or 14-inch bottoms for either tractor.
I'm sure someone on here has had personal experience and can give you more good thoughts.
Stan
