JD A 800 801 Hitch
David A
02-05-2002 17:23:36
How do I determine if my 1951 A, serial number 680654, has the 800 or 801 hitch? What is the difference between them?
Thanks in advance for your comments. David A
Steve K
02-07-2002 04:31:53
 Re: JD A 800 801 Hitch in reply to David A, 02-05-2002 17:23:36
I stand corrected if I'm wrong, but I was always under the impression that the 800,801 hitched were introduced with the numbered series tractors. However, they will work on the lettered series with power-trol. Steve
RLA
02-06-2002 17:31:28
Dave, I believe the 800 has a rather large crank at the top of rh lift link. The 801 series has both sides adjustable lift links & a draft links for depth control that mount on rear axle. The large crank type can remove your seat when lifted at the wrong time.RLA {Been there & done it}
