2520 sheetmetal
eric Thomas
12-04-2003 09:28:28
Desparately looking for sheetmetal for a JD 2520. Need a hood and all other sheetmetal. Tractor had a loader and the hood was destroyed need I say any more! would like to at least have a hood for the old girl. Any help would be grealty appreciated! Eric
Ben Van
12-31-2004 19:09:01
 Re: 2520 sheetmetal in reply to eric Thomas, 12-04-2003 09:28:28
You can buy a 2520 hood at Gary"s Imp. at Bridgeport, NE with a little damage. There is also one with some fire damage at Meyer"s Salvage at Aberdeen, SD. You can get about two 2510 hoods at Northeast Tractor Salvage at Lyons, NE and also at Meyer"s. They will cost you about $250 to $400.
If your looking for rear engine side panels, well good luck finding them. If a 2520 or 2510 comes in for salvage, they"re always the first things to go. If you can find them they will cost you about $250 to $600 for the set. You have to cut down a 2510 panel to fit a 2520.
Fuel tank panels are kind of hard to find, but there is a few at Meyer"s for about $40. 2520 panels are interchangable with a 2510.
Side screens, you can still buy new ones from John Deere for about $62.
HAPPY NEW YEAR!!
Huckleberry
12-05-2003 08:24:37
Cook Tractor in Clinton MO may be able to help you...660-885-2287. ask for John.
mike
12-04-2003 12:17:02
There is no decent sheet metal available for them. I tried to find a decent hood last year,called all over the country,no luck. I sent the hood to a body shop to get it straighted and then sent the tractor to have it fitted($950.00). I bought the only set of side shields that I could find for $700.00,a set of perfect original fenders for $750.00,and a set of original battery boxes for $250.00 I have more in replacement tin and bodywork than in the tractor itself.
Craig
12-04-2003 11:49:45
Sheetmetal for the 2510/2520 is hard to come by. I know because I redid my 2510 some years back. Try one of the big salvage yards...Abilene Machine, etc.
You will probably pay dearly for a 2520 hood. I hope not, but these yards also know those parts are hard to come by.
Larry
12-04-2003 14:38:36
 Re: Re: 2520 sheetmetal in reply to Craig, 12-04-2003 11:49:45
I could be wrong but I think the hoods for the 2510 & 2520 are unique to each other. They have different mufflers. I was considering a different hood for my 2520 and found their were none around. I will have a body man work on it as it isn't that bad.
Craig
12-04-2003 11:53:07
Is the hood repairable via local bodyshop? If it has been damaged beyond repair...does this mean you have more serious problems with the tractor fuel tank, radiator, etc.?
