Crank Question
Dave in MA
02-05-2002 15:03:19
I am in the process of rebuilding a JD 60 and have the crank pulled.
When I took it to the machine shop they informed me it had been turned
before and could not go any further because bearings were not available
(this was in October). I recently got the latest issue of Green
Magazine and Renaisssance Tractor is now making undersized bearings.
Does anybody think it's a bad idea to go his route and turn the crank
again to utilize these bearings? Thanks for the input.
Frank
02-06-2002 12:46:13
 Re: Crank Question in reply to Dave in MA, 02-05-2002 15:03:19
Dave:
I'm not sure what the od of a 60 rod journal is, but lets say it's 3.000". If it had been turned .010" before, and you go .010" again, you'll still have 98.6% of the original cross-sectional area.
I wouldn't worry about losing any strength, and I think that might work out to the less expensive route, but you'll have to check out your options.
Frank
pat
02-05-2002 17:03:11
Dave,
There are several things to consider before making a decision.
First, the intended use of the tractor - if it is to be restored for show, farm work, or stock pulls, I don't see a problem with going oversize. Especially with the size of the journals on the JD 60 crankshaft. Bear in mind that many pullers will offset grind a rod journal, removing .250" of material to gain added stroke-with decent results. This being said, I feel reliability would not suffer if the tractor is used normally. If you were building a 100 hp JD 60 with very high compression or very high RPM, I probably would NOT recommend this repair.
The second factor is the shop doing the work. The shop must be aware of the neccessity to ensure the oil holes in the crank still line up with the oil hole in the bearings after grinding. This is due to the oil hole being drilled through the crank at an angle starting at the center of the journal. When material is removed, the hole is moved to one side or the other and is no longer in the center. This is simple to remedy by grinding, but absolutly neccessary!
I hope this helps, If you have any more ?'s E-mail me and I will be glad to help. LATER, Pat
brett
02-05-2002 16:46:05
i think you should price everthing before you decide what to do. if the new crank is chaper that having the old one turnd you should go ahaid and buy a newcrank and not do anything with the old one and use regular bearings
