JD A from ground up.......
Bamamule
02-04-2002 19:25:18
I've started restoring a 1950 JD A that should have been parted out but..... Anyway the tractor was an all-fuel but the block was ruined and I purchased a LP block and pistons for a JD 60. I was wondering if this is a simple swap or a major nitemare? Any input would be appricated.
BobTGS
02-05-2002 07:35:36
 Re: JD A from ground up....... in reply to Bamamule, 02-04-2002 19:25:18
Everything you've got there will bolt together.But you will most likely have to run it on high octane fuel and be careful with the ignition timing .Bob,from Triple G Service.
