G trans
Doug
12-04-2003 07:58:14
I have low serial # G, took the shifter plate off top of trans looking for gear noise, everything looks good, shafts tight. Jacked up and run in gear doesn't seem to make the noise it did on ground. wondering if anyone knows of where the problem usally comes from? Could it be the clutch gear to trans gear? THAANKS DOUG
DOUG
12-04-2003 11:02:57
 Re: G trans in reply to Doug, 12-04-2003 07:58:14
Just run it again, seems like bottom shaft rt side has woble to it. Can't get a good hold of it but seems to woble. Have to have trans in gear to make noise. Looks like reduction cover has to come off to reach that bearing. Thanks DOUG
easydoesit
12-08-2003 09:01:31
 Re: Re: G trans in reply to DOUG, 12-04-2003 11:02:57
Hey Doug, Yea the cover does need to come off. I replaced a bearing in a JD50 about two weeks ago that had that bearing go down. Alot of shims under the bearing cover there. If you need to get the shaft out you have to start from the top though. Good luck. I got some G tranny stuff if you need it. Keep me posted. easy
[email protected]
easydoesit
12-04-2003 10:26:03
Doug, Wow, that's a hard question to narrow down...you know that there is a bearing at each end of the main gear shafts and a bearing in the middle of the top shaft, under the gears in the bottom shaft and also in the first reduction gear cover. If you put the transmition in neutral and engage the clutch 1/2 of the counter(top) shaft runs and the bottom shaft is still but you do hear the first reduction gear into the clutch(the highest speed reduction). That may tell you something. easy
