JD R main bearings
smoker
02-04-2002 14:31:41
Has anyone had to replace the crank main bearings in their R? My parts manual shows that you can only get a complete bearing housing unit on exchange from JD. JD does not produce or service this anymore. They did have a way to get one but it will cost about $210 outright. That was for the standard size and I am going to have to have one that is undersized and I don't know if they can get that one. Does anyone know of a bearing that will fit in the bearing housing so that I can take it to a machine shop and just have a new one pressed in. I think it might be an aluminum sleeve that serves as the bearing.
Gpower
02-04-2002 17:48:58
 Re: JD R main bearings in reply to smoker , 02-04-2002 14:31:41
You can get new bearings thru deere. I have priced them, 44.00 for the right side and 80 for the right, maybe vice-versa. You can get just the bearing. If they have to turn the crank, just take them the bearings and the housings, a machine shop can size them to the crank. Good Luck
smoker
02-04-2002 18:56:33
 Re: Re: JD R main bearings in reply to Gpower, 02-04-2002 17:48:58
Do you have a part number? My parts book and John Deere's book neither one show a bearing sleeve by itself. It only shows a complete reman exchange unit that they can no longer get.
Gpower
02-04-2002 19:26:26
 Re: Re: Re: JD R main bearings in reply to smoker , 02-04-2002 18:56:33
R348R that is both, the 44 dollar one was the rod bearings.
smoker
02-04-2002 19:43:03
 Re: Re: Re: Re: JD R main bearings in reply to Gpower, 02-04-2002 19:26:26
Oh yeah, I didn't see that. Right there it is below the exchange unit numbers. Thanks a bunch.
