All fuel 60
nigelB
02-03-2002 06:05:24
A question for you alls can a "60"standard be converted to all fuel,as you know gas is helishly expensive over in the UK and it would be handy for ploughing. I now fergi,s used to make a conversion using a spacer head gasket to reduce compresion,i dont know about the gas manifold and duplex carb though? regards nigel burgess
Clooney
02-03-2002 08:57:00
 Re: all fuel 60 in reply to nigelB, 02-03-2002 06:05:24
nigelB, you could do it but even with high fuel costs I doubt it would be worth it.
~You will need to lower the compression with either a block spacer, new pistons, machined pistons, head spacer or?
~You will need an all-fuel carburetor or rebuild yours with the all-fuel parts.
~You will need an all-fuel hot manifold.
~You will need a different fuel tank with 2 tanks, or rig a way to have a separate starting tank for gasoline to start & warm it up.
~You will need a good warm thermostat or shutter system to allow the coolant temperature to be kept above 200-210* while burning other than gasoline.
~You will probably have to remove the fuel tank heat shield under the fuel tank.
~You will need to have a way to drain the excess fuel off that enters the crankcase during use.
~You will need to retard the ignition timing some.
~You will probably still need something I missed here.
~Even after modifying your 60 to burn tractor type fuel you still won't be able to use diesel fuel or heavy heating oil as they won't work worth a darn, & will probably be stuck with a mixture using part gasoline or burn pure kerosene. ~Depending on your soil & type of plow you are pulling you will probably have to go down in plow size or a lower gear due to lower horse power & might not gain much due to longer run times to cover the same ground.
zane
02-03-2002 18:09:14
 Re: Re: all fuel 60 in reply to Clooney, 02-03-2002 08:57:00
Clooney: I doubt if you missed anything. Excellent article.
G Taylor ....LP or CNG?
02-03-2002 19:42:10
 Re: Re: Re: all fuel 60 in reply to zane, 02-03-2002 18:09:14
What is the local price and avalability of LP (propane) or natural gas(methane/CNG) as well as tractor gas,kerosene & #2 farm diesel?
nigelB
02-04-2002 11:08:20
 Re: Re: Re: Re: all fuel 60 in reply to G Taylor ....LP or CNG?, 02-03-2002 19:42:10
Thanks for your comments, heres those local prices for you:US GALS propane: $1.32 tractor diesel: $1.06 road diesel: $3.92 kerosene: $0.87 gasolene:$3.97 can you see why we want to run a all fuel now? regards nigelB
G Taylor ...yikes$
02-05-2002 14:35:47
 Re: Re: Re: Re: Re: all fuel 60 in reply to nigelB, 02-04-2002 11:08:20
Nigel where are you located, I assume those are US$ as well? Any natural gas avalable anywhere? I wish kerosene was that cheap here for my turbine generator. I'm suprised there is no farm/off road gasoline or maybe there's just too much temptation? The price on LP would require hundreds of hours use per year in order to payback. Are there any 620/630's avalable,they were the most efficient or very close, of any gasoline fueled tractors? For the difference in kerosene price it's tempting to find a blend of gasoline/kerosene that the tractor will start & run on without detonation. A 195F thermostat,shutters,block heater & high energy multiple spark ignition would improve the odd's of success.
