48 JD G
Nathan
12-03-2003 21:41:20
Hi guys.
I have a 48 G that I have overhauled about 2 years ago and she has always ran good for me. Then, the other day, I fired her up on a cold morning to auger some corn, and it popped and banged and it ran on one clyinder for about 30 seconds, after that, she ran like normal. I didn't think too much of it, it had sat for a while. Later, it did the same thing. I checked the plugs for moisture--none. Gapped and changed plugs, checked wires and distributor out, everything seems in check. Looking for other suggestions.
Any help appreciated.
Nate
DP
12-04-2003 08:22:07
 Re: 48 JD G in reply to Nathan, 12-03-2003 21:41:20
You didn't say how long the tractor set between times you started it. If it had time to cool completly down again, it might just be that your fuel is set too lean. Does a little choke bring it out of it? Just a thought! Good Luck Don
Nathan
12-04-2003 22:07:13
 Re: Re: 48 JD G in reply to DP, 12-04-2003 08:22:07
I have put new plugs in it, no help. It did sit long enough to cool down between starts, but started the same day. Choke seems to help, but not much. Like I said, it doesn't appear to be getting coolant in the cylinders, I changed plugs, checked wires, and the distributor for moisture, wear, and point gap. also checked cap for crud. It has always started and ran so well an now this starts all of a sudden. I was wondering on fuel myself, but I wasn't sure, seems to run fine after about a half a minute.
Thanks
Nate
Ron
12-03-2003 21:56:17
Change or at least switch the plugs from side to side... All single-carbureted 2-Cylinder JD's "Loaf" on one cylinder when they Idle...eventually fouling that plug... Other than that, check the mag cap for moisture, or a bad plug wire. You can tell which cylinder is not firing by opening the petcocks.. Sometimes, just pulling the "dead" Cylinder's plug wire out of the mag a little will intensify the spark enough to get that cylinder firing...
