Clooney help with a 530
Brandon
01-31-2002 14:54:34
I need a little help with some information on a 530. I need the torque specs for the block nuts, head bolts and the valve clearances.
Clooney
01-31-2002 16:26:58
 Re: Clooney help with a 530 in reply to Brandon, 01-31-2002 14:54:34
Brandon, valve (tappet) clearance is .020" hot (not just idle it around hot but work it a while hot). If just putting it back together, set the clearance to .023"-.024" cold to get it running then re-adjust to .020" when hot.
~Head nut torque is 105' lbs, working from the center out in 10# increments. ~I personally don't torque the block to case nuts but believe the torque is 166' lbs.
Brandon
01-31-2002 17:32:33
 Re: Re: Clooney help with a 530 in reply to Clooney, 01-31-2002 16:26:58
Thanks Clooney
