M Touch-o-matic leaking
help please
Bama Binder
01-31-2002 10:11:54
The hydraulic touch o matic on my M is leaking fluid. As near as I can tell, I need to remove the rockshaft and replace the gasket.
Question: Do I need a gasket or would a good high temperature high pressure sealer do the job? Is there a danger to using the sealant like a good silicon based gasket seal??
UPdeere
09-08-2004 15:53:43
 Re: M Touch-o-matic leaking - help please in reply to Bama Binder, 01-31-2002 10:11:54
Hi,
I was wondering if you could tell me what type of fluid you put in the touch o matic on a M. Mine appears to have no fluid in it. i dont have a operators manual for the tractor so i cant find out. Any help is appreciated. Thanks.
Paul
Check this out
02-01-2002 07:13:46
Look for burrs ! one time I did everything but , and had the shop work on it and said they filed off the burrs and that stoped the leak !!! (still costed enough)
Wayne in Tn.
01-31-2002 16:28:01
BB, I have never had a problem with new gaskets. Look closely, your leak may be coming from the seals at the end of the rockshaft, where the arms are attached. The oil will run back under the housing toward the center of tractor. By the way, I am near Florence, Al. where are you??
Bama Binder
02-01-2002 05:28:13
 Re: Re: M Touch-o-matic leaking - help please in reply to Wayne in Tn., 01-31-2002 16:28:01
Thanks for the help. I checked all over the unit and I'm pretty sure it isn't leaking at the ends near the rockshaft. In fact, after I scraped away all the dirt and grease, I'm not real sure there is a gasket there at all. It isn't leaking at the hydraulic lines either, which was my first thought. I think I'll just call the local Deere dealer down the street and get a gasket set and go through the hydraulics.
I'm in Birmingham, AL but get up to Redstone Arsenal once a month or so for Drill.
Drail
02-04-2002 20:23:41
 Re: Re: Re: M Touch-o-matic leaking - help please in reply to Bama Binder, 02-01-2002 05:28:13
Just wanted to wish you luck finding a gasket set. My JD dealer said he could get me one. A week later he gave up. I built my own out of gasket material. Comes to find out , the leak was on the suction line. I had to build the "gromlet" from a rubber bushing. GOOD LUCK !!!
