JD 1040
Grant
12-03-2003 18:03:00
I'm searching for any information on a JD 1040 CDN tractor, 2WD. How many HP? What years were they made? Any problems / reliability? Approximate weight of machine?
It also has a JD 145 loader. How much weight can it lift? How is the hydrolic system on this tractor? How is the front end when used with the loader?
Any information would be appreciated. Thanks, Grant.
david val
12-04-2003 13:14:11
 Re: JD 1040 in reply to Grant, 12-03-2003 18:03:00
the 1040 that i know (mannheim)is a 54 engine hp tractor. it is the evolvement of the 1030 and 1020. so it's close in weight, a little heavier. it is strongly built, options for synchronized transmission, hi-lo shift unit(the new type enabeling tow starting) or creeper, many configurations (low, high, compact and wineard). 3 cylinders 179cid diesel. closed center hydraulics with power steering and up to two remotes options. one of the noticable advantages over the 1020/30 is a faster reverse gear in the synchro model. i think the us equivalent is 2150.
david
Grant
12-04-2003 16:59:45
 Re: Re: JD 1040 in reply to david val, 12-04-2003 13:14:11
Thanks for the info David. Do you know what years they were made approximatly?
It's a nice looking little machine. No leaks and appears to be kept under cover. I haven't seen it run yet - maybe this weekend.
Grant
david val
12-05-2003 00:37:04
 Re: Re: Re: JD 1040 in reply to Grant, 12-04-2003 16:59:45
the ones that came from europe (germany and spain) to my part of the world came in between 1981 to 1986 and were replaced by the 1750 in 1987. david
Grant
12-06-2003 14:24:12
 Re: Re: Re: Re: JD 1040 in reply to david val, 12-05-2003 00:37:04
Thanks for the information David. What part of the world are you in? I'm on Vancouver Island.
