730 Questions
John
01-29-2002 03:39:46
Hi guys:
I'm wanting some more information on 730 Diesels. Did they all come with flat top fenders or was this an option? Is it better to find one with a pony start or electric? How much work will they handle, will they mow hay, pull 4-16 plow, or any other light farm chore?
Thanks
Paul
02-04-2002 19:59:42
 Re: 730 Questions in reply to John, 01-29-2002 03:39:46
I just bought a 730 about a year ago. It has fenders witch were a option. It is an electic start. I live in PA where it get cold. I have had no problems this winter it does have a factory coolent heater on it I plug it in for about a hlf and hour and then it will fire right up. It is our main round bale feading tractor so it starts about every other day. She will knock when she first fires up but she will calm down in a little bit. I wanted to see what it had under the hood so I hooked the 4-16 witch we have for our 140 hp tractor well it worked the old 730 and it poored out the black smoke and pulled them. I was impressed, it just made the frontend light and it even has front weights. I have put about 100 hours on the tractor pulling a haybine. It pulls it great I would not trade it for one of those red tractors I use to use. The hydraulics are fast and the hand clutch is great because you can turn side ways and watch the mower.
I also used it to move round bales, it is good just makes the front end light. I think it is a good tractor, my only thing is check the bolts that hold the front end on. They tend to work out, not a pertty picture. Had the front end fall off while mowing in 4th gear. After putting the front end back under I was a little more careful.
I took it to the fair to see what I could do, it is a farm tractor nothing done to it. I out pulled the ford dealers ford 5000 that they had turned up, now it was only by 6 in but it was farther and thats all that matters. I came in 3rd, not bad for a straight off the farm tractor. But I was very surprised when I went across the scales it weights 10,100 it has 16.9-38 loaded. no rear weights and front weights. Well just my 2 cents they are a good all around tractor and I love the electic start.
buckeye al
01-29-2002 15:06:49
You ask if it is better to find an electric start or Pony start. I think it all depends on how you look at the machine & how you use it. I once started mine (pony start) at -12* F just to see if it would do it. Once the pony was warm enough to roll him over with the valves closed, to my surprise it started right up.
I won't ever do that to it again!
The harshness of the diesel knock at that temperature is absolutely incredible! Was enough to make an Amishman say some Hail Marys!
The pony (if maintained properly) is usually a more sure winter start than electric but electrics start quick & easy most of the time. In the summer, while I'm still waiting for my pony's carb to fill with fuel, the electric start is already rolling out of the barn. By the time my pony's warmed up a bit and ready to start motoring the diesel, the electric can be hitched to a trailer plow & be on it's way back the lane.
I believe electric start became more popular because they did start well and were MUCH lower maintenance than a pony even with their eight battery posts and clamps. The pony carb (at least mine) seems to need readjustment between summer & winter. It takes two sets of points & condensers. It is another crank case oil level to maintain with a different grade of oil than the diesel uses. It has a transmission oil level. It has a clutch to be adjusted periodically and an oil bath air cleaner that MUST be maintained because it is the fresh air inlet to the diesel's crank case. You can't change the pony's oil without contaminating the diesel's oil 'cause the pony's oil drains into the diesel's crankcase. If you have any fuel system leaks it will always be out of gas as it only holds a quart to start with. Sometimes you have to choke the pony a bit if it starts to die or you have to let off the cranking clutch or maybe both. Once the diesel is rolling you close the valves & then throttle up the diesel. As soon as it starts, disengage the clutch. Usually once you close the diesel's valves & commit to starting the diesel, it's all be over in just a few seconds. Some people just never quite get the hang of it & hate the thought of having to contend with that little screaming beast on top. My Dad is one of them. If I start it, he'll run it. If I don't, he'll walk a mile to get to an A, artificial knees and all. Lot simpler to poke a button 'till it starts to putt then let go.
Maintenance is the key. A pony start is more to maintain & some people have trouble maintaining an anvil. It is my opinion that the 2 cylinder diesels (pony or electric) are wonderful, tough, incredibly fuel efficient hard working machines each with a unique character. You have to decide upon the machine that best fits you, your character and how much TLC you're willing to give to it. I'm one that likes pony starts. Most of this is just like the color wars. Which one is "best" all depends on what you do with the machine, how good your dealer support is and some times not much more than what color Dad ran.
I look back & see I've typed a lot & it probably isn't worth much but it's my couple o pennies for today.
LLOT.. Long Live Old Tractors (of all colors).
Later.
JDJIM
01-29-2002 13:23:19
Dad bought a 730D new in May 1960 , must have been one of the last ones made , electric start , 3 pt and couple years later we put a JD oem wide front on it , quite a tractor in them days , wish I had it today but traded it for a 4020 in 1967 .
The rest of the guys are right , not much on starting in cold weather , and seems like it always needed batteries . The pony start was more of a all season tractor . Lots of people had trouble with the ponys but most of it was lack of care and proper operating . One neighbor had trouble with the pony clutch , kept on grinding away on it and then he found out the flywheel was loose , not much on maintenance , he got so mad at Deeres he went Red . We never used it much in winter so we got buy pretty good with the electric . We never had the flywheel come loose , but it was checked every year , If I remember that happened occasionally on the 2 clys didn't it ?
Far as plowing , we pulled a 4-14 JD 666 plow , in this NC ILL. gumbo it had it's hands full , would never pull 4-16's . Also had a 830 Electric start , pulled 5-14's with it , the 830 did a little better with 5-14's than the 730 did with 4-14's . We had both of them opened up and they would put out pretty good puffs of black smoke .
We had duals for both of the 30's , pulled a 14ft disk with the 730 and 18ft with the 830 , both handled the job well .
Chicken George
01-29-2002 12:40:04
John,
I have a 70 and a 730 Both are pony start, these are nice tractors,But they are "working"tractors. They have been on my farm 20 or so years, I have had no problems with the ponys, John Deere used to advertise the pony start as a "northern tractor" as it would start in ANY temp.and the pony would warm up the big engine making starting easy in cold climates. Today most fellows like to turn a key and "GO".They don't like to mess around with a pony. With an Electric start you are buying 4 large 6v.batteries. On my tractors I use one little $15.00 12v.lawnmower battery as I have converted them to 12v. system. It does not take much to turn over that little pony and they start right up if you have them tuned proper.
The 24v. electric starter is VERY costly to repair/replace IF it fails, of course the PONY is COSTLY to repair also. I believe the pony is given a bad rap it doesn't deserve. I don't think you can go wrong with either! I pull 4-14's trailer plow in any soil and they are advertised as 4 botton in any soil 5 in many. But I think 5 -14's would be too much in all but the most lightest soil
Stan - Florida
01-29-2002 06:42:14
A brochure I have (dated 11-58) talks up the "Modern new FENDERS with dual HEADLIGHTS". In this paragraph it states that "These new fenders and lights are available as extra equipment on all "730" General-Purpose Tractors."
That would indicate to me that they were optional. It is obvious when going through the brochure that Deere was pushing them, as there are only a couple pictures of tractors without fenders.
Stan
Frank
01-29-2002 06:39:06
John:
You'll probably get a bunch of opinions on this, but here are a few of my thoughts:
Pony vs. Electric start : The pony is pretty dependable, as long you have one in good repair and in tune. Major repair can mean major dollars (but parts for all these old ones are pretty pricey anyway). If you are in a cold climate, the pony will start when an electric is just getting a boost from the charger (and a coolant heater can't hurt !). Electric is generally viewed as a simpler system, but you then have to contend with the 24V system, which can be expensive to repair and maintain, too. The electric will really suffer in low temeratures. The pony method is kind of neat, but then if you shut the tractor off in the back 40, and then on re-start you discover you didn't fill the gas tank, you'll have a long walk to think about it !
As far as flat top fenders, fenders were an option back then, and not everyone opted for them. They can get in the way of loaders, and had to come off when you mounted the picker.
I have a 70 Diesel, the grandad of a 730. We pulled 4-14's in decent soil. Our neighbor had a 730 with 4-16's and always said it was either a good load for it, or a tough load for it, depending on conditions. It really depends on your ground, and the weight you put on the tractor. Rule of thumb, I think a 730 was right there sort of between a 3010 and a 3020 in power. I don't know that I'd call pulling 4-16's a "light farm chore". Way back when, that load was one that would have made the neighbors stop and watch.
As far a mowing hay, it will run a mower with a crimper on the back. Our neighbor puller a 42 combine with his (the pull-type version of the 45). I'm not familiar with the load presented by today's round balers, so I can't offer a guess.
I hope this helps.
Frank
Tyler B
01-29-2002 06:24:19
John
To my knowledge flat top fenders were an option, however this may be that the one's that ive seen without them were only missing them. One thing that I know for sure is that electric is much better than pony start!(Unless the pony has been totally rebuilt by someone who knows what they're doing) My grandpa pulled 4-14 with his 730 gas without much problem. Since the diesel has a bit more power than the gas, depending upon the soil it should handle them. The 4-16 would probably be about all the 730D would want though.
Donwisc
01-29-2002 09:48:06
 Re: Re: 730 Questions in reply to Tyler B, 01-29-2002 06:24:19
Elect start 730 and 830 are always more in demand and get a higher price. If the ponys offered so many good features why did JD go to the Elect start.
Also there are a number of suppliers out there offering 12 volt retrofits to replace the ponys so you can draw your own conclusions.
