Duals for a 720 JD???
Tyler B
01-27-2002 20:59:03
Were duals offered from the dealers when they sold new?? I have a set that came with my 720 but upon inspection, the attachment hub is red on the side that faced the tractor hub. I know that the tractor was used in gumbo bottom land. Any imput would be helpful.
JDJIM
01-28-2002 18:30:47
 Re: Duals for a 720 JD??? in reply to Tyler B, 01-27-2002 20:59:03
M&W was the first to come out with duals that I know of , we had a set of hub mounted duals on a 730D in early 60's . Had the 3 u bolt hub and 9 bolt wheels . The 31/8 dia axle of the 720-730 is the same size as 30 -4010 and 3020 and probably some others . JIM
Mike Aylward
01-28-2002 11:06:43
Tyler, duals were not a factory option for the 720's (to my knowledge). Factory duals were used on the New Generation tractors and have tapered wedges in them like a regular cast wheel has. I would imagine that the set you have is an aftermarket set which were available from farm supply stores and tire dealers for many years (and still are from the tire dealers). Yours are probably mounted to the axle with U-bolts. Your 720 has 3 1/8" axles which were carried over and used for many years thereafter, so duals for a newer tractor will fit right on it. Hope this helps. Mike
