B steering loose
Gary
01-27-2002 18:36:16
39 B- took off nose piece and the plate held on by 4 screws and found gear- when i turn wheel the whole column moves ---is that suppose to happen--how do i fix that?? thanks
Will P
01-27-2002 20:02:11
 Re: B steering loose in reply to Gary, 01-27-2002 18:36:16
You mean the shaft that goes down to the wheels? Then the bushing that the shaft rides in is probably shot. It is an ecentric bushing to tighten the steering. Not just a bushing that you can replace with whatever. Deere douse have this bushing as I have replaced it myself on my B. It cost me $95.00
Will P
Larry E
01-27-2002 19:53:53
A maintenance manual tells you all of this,plus anyting else you want to know
