530 ventilator pump
Greg
01-27-2002 04:28:04
how do I stop a oil leak between fan shaft tube and ventilator pump? my 530 parts book doesn't show any kind of seal in there. my 620 parts book shows an O ring. Thanks Greg.
Ron
01-27-2002 08:11:13
 Re: 530 ventilator pump in reply to Greg, 01-27-2002 04:28:04
Replacing the "o" ring is ofcourse the Best answer.... For other gasket repairs...I have had excellent results with using a good automotive Silicone--applied thinnly...WITH a LOOP of Dental Floss set into the silicone, inside of the bolt holes... This was commonly used to seal Aircraft engine crankcase halves together..( only they used aircraft Permatex).AND I don't use Permatex...!!!!! Actually, they used a "Silk thread"...The Dental Floss works fine.....
