4430 jd
r. jones
12-03-2003 14:28:31
i am having steering problems with a 4430. every thing works good , but no power steering... my brakes, trany, 3 point, work good, no power steering any ideas,,,,, ,
twopop
12-03-2003 16:16:42
 Re: 4430 jd in reply to r. jones, 12-03-2003 14:28:31
NO power steering.does the steering wheel move easily or difficult to turn?
rlj
12-04-2003 15:09:12
 Re: Re: 4430 jd in reply to twopop, 12-03-2003 16:16:42
you can not steer it, have to yous brakes
G-MAN
12-03-2003 15:38:56
How old is the 4430? The early ones used the steering valve similar to the one used in the New Gens, and they're a pretty complicated little item - real touchy about being properly adjusted when being rebuilt. The later tractors switched over to the hand-metering-unit and the valve block under the hood.
rlj
12-04-2003 15:18:23
 Re: Re: 4430 jd in reply to G-MAN, 12-03-2003 15:38:56
i think its a late model, but not sure,ill pull hood of and look to see if there a block there thanks,,,,,
