420U
Darald
01-26-2002 09:28:02
I found a 420U in nice condition but it does not have a PTO or a 3 point...can these be installed preferably with a live PTO. Thanks
Steamer
01-28-2002 14:33:10
 Re: 420U in reply to Darald, 01-26-2002 09:28:02
Hi,
It can be done. For the 3-pt, I presume the lack thereof also means there is no rockshaft under the seat. You'd have to add that, along with the steel hydraulic lines to the pump. You might even have to add the pump to the front of the engine (I'm unsure if non-rockshaft equipped U's have the pump in place or not anymore).
For the PTO, a standard (non-live) PTO would require removing a cover plate on the rear and bolting on the PTO unit. For a live PTO, you'd have to change the flywheel, clutch assembly, bell housing, center frame and transmission. That's the really hard add-on.
The live PTO's in these machines required a mating 5-speed transmission, which had twin power inputs. One is the main drive, and the other is the PTO drive. The center frame and bell housings are different to accept the dual clutches (one for PTO and one for drive) and coaxial power shafts.
Generally speaking, this was an option that was ordered on a machine from the factory, and not field upgraded. If you find the correct doner machine you could pull off such a conversion, though.
Also, there is another option on these machines that allows shuttle shifting, called a direction reverser. Many U's were so equipped and this DR unit fits in place of the center frame. There are two variations on the 420 (early gear-type and later differential type), but both preclude the adaptation of a live PTO arrangement.
Dan
01-26-2002 12:48:23
The 3 pt and pto could be installed but you would probably have to find a donor tractor as I don't think parts would be available from Deere and if they were your banker would yell. Suspect if you want live pto and 3 point it would be easier to get a later model tractor. I think it would be not too hard to find a 430 u with pto and 3 point but live pto would be more difficult.
