530-630
VC
01-25-2002 04:21:13
What is the horse power of the JD 530 and 630 and did all of these come with live hyd. and live power? Also what is the difference between a 530-630 and a 520-620 newer,older,size? Thanks.
G Taylor 620/630 most efficient gas engine
01-26-2002 19:47:14
 Re: 530-630 in reply to VC, 01-25-2002 04:21:13
The 620 set a gasoline economy standard that is seldom even approached today. HP/hour developed per gallon of gasoline makes the 620/630 cheaper to operate than many diesels. A 620 at full power will burn more fuel per hour than a 520, as it's making more HP. This site & Rummeys have the tractor specs listed if you care to click on the text/icon.
David
01-25-2002 17:19:11
Cosmetics are the biggest differences in the 20-30 series. No other big changes were made. As far as the horsepower goes, I have dynoed both a 520 and a 620. GOOD runners will surpass the ratings (37 for my 520 and 46 on my 620). Both engines have recently been gone through and have less that 400 hours on rebuild. 520-530's - not too bad on fuel, and powerful for their size. 620-630's, lots of power, too, but a MUCH thirstier appetite to go with it!
Ron
01-25-2002 05:10:03
the 520 & 530 are about the same, as are the 620 & 630..... the sheet metal looks a little different... The 520 & 530 are rated at 34 HP and I think that is an over-estimate.. The 620 & 630 are rated at about 44 HP...a Huge jump from the old All-Fuel "A"..... These are for "Gasoline" engines... All-Fuel engines had about 7 or 8 HP less... Some say the power steering in the "30" series was improved over the "20" series.. The "30" series had Quieter mufflers, and larger tires...both can be used on the "20" , and 50, and 60 series...
