Gas Octane ??
matt
01-24-2002 19:12:43
what is the best octane for a 1937 b cause when it gets warmed up it dies sometime what is the problem the gas or something else thanks matt
matt
01-25-2002 16:18:17
 Re: Gas Octane ?? in reply to matt , 01-24-2002 19:12:43
thanks guys now if i could get you guys to do it for me
John T
01-25-2002 06:33:16
Matt, regular 87 octane is fine, those old tractors have low compression and were designed for even lower octane gas and/or distilate fuel even. When she dies after warm up is she still getting plenty of fuel (carb or float problem) but as the post below stated, a problem only after warm up may well be ignition related such as a condensor or coil. Assuming the carb and sediment bowl and filter are ok (not a fuel problem) ?? I would check the points for proper gap and condition and clean the plugs for starters, and since points and condensor are cheaper than a new coil, would then try that first. Good luck Ol John T
Mr. Nobody
01-24-2002 20:29:21
It's probably not the gas----the usual cause of this problem is a bad coil in the magneto---the insulation breaks down from repeated hot/cold cycles, and eventually, when it gets warm, will just quit working. The octane rating of today's gasoline is more than adequate for the low-compression engines.
