620 Power Steering
POPPER DICK
01-24-2002 19:00:59
I ordered a 620 manual and no where in it is reference to adjusting power steering pressure. I think the adjusting screw with locknut on the slave unit is a pressure adjustment. I am replacing my power steering pump seals. They blew out within 10 minutes of my tightning the adjustment screw locknut on the slave unit. It was leaking a little. I held the screw with screw driver while tighning the locknut. Where can I find manual reference of power steering data.
POPPER DICK
01-26-2002 18:26:17
 Re: 620 Power Steering in reply to POPPER DICK, 01-24-2002 19:00:59
A little over a year ago someone through this forum gave me a phone number to john deere for ordering manuals. I have misplaced that number. Could anybody help? Sorry for the carelessness!!
Thanks Dick
Frank
01-25-2002 03:54:43
Popper Dick:
The manual you want, just for power steering, is SM-2050. Last I heard it's 14.95 + shipping from the JD.
Frank
ChuckW
01-24-2002 20:18:48
an IT manual has the information about power steering, also JD manuals have information. I've been through many of these and I find the main problem is not the pump or adjustment pressure but rather the motor or vane wipers. You have to dissamble the pedistal to replace. What happens is generally one of the pins holding the wiper piston will be broken and also pressure will be leading past the rectangle seals. Get a parts manual and you can see how the assy is constructed. Good luck.
POPPER DICK
01-25-2002 03:50:52
 Re: Re: 620 Power Steering in reply to ChuckW, 01-24-2002 20:18:48
Can you suggest where to obtain these manuals?
Thanks for you reply.
Dick
Ron
01-25-2002 04:58:14
 Re: Re: Re: 620 Power Steering in reply to POPPER DICK, 01-25-2002 03:50:52
You can get them at TSC, Quality Farm Fleet...
They are not bad books....
